Another GSOC application
Wed Mar 26 15:29:52 UTC 2008
Sven.BIEBAUT at be.thalesgroup.com wrote:
>     <snip>
>      Another idea concerns a project that may become my Undergraduate
>     Thesis. I've been thinking in adapting I-Logix Rhapsody in order
>     to have a UML tool (with great code-generation capabilities) for
>     rtems on erc32. This would make possible the use of modern
>     Software Engineering concepts, leading to fast model-driven
>     development and analysis of real-time embedded software.
>      <snip>
>     André Keller
>     Hello,
>     This IMHO could do wonders for the adoption of  RTEMS on a lot of
>     avionics/military projects where Rhapsdy is very much used. The
>     great thing about an adaptor in rhapsody is that it only abstracts
>     the OS API, which means that as soon as it is written, it is
>     peanuts to have it on others as you only need to select a new
>     build environment. Since this is gcc for all RTEMS, you only need
>     to modify a few batch files/scripts to add a cpu.
>     As Telelogic (formerly known as i-logix) has a mingw based adaptor
>     for win32 console applications, the necessary batchfiles can be
>     adapted from there to make it work. I do not know if there are
>     license issues with that approach. That might need to be verified.
Sven .. do you have any contacts that could let Andre do this for
them as a summer job?
>     HTH,
>     Sven Biebaut
