Deleting IDLE task ...
Leon Pollak
leonp at plris.com
Sun Mar 30 14:54:09 UTC 2008
On Sunday, 30 בMarch 2008, John Pickwick wrote:
> Hi to all :=)
> There had already been a topic on this but I've got a new problem.
> I'm using LEON2 bsp and RTEMS4.7.1 and I want to delete the IDLE task to
> avoid the use of the PowerDown register (which is included into the default
> IDLE thread).
> To do so, just at the beginning of the Init task, I tried to retrieve the
> IDLE task id (rtems-task-ident) and then to call rtems-task-delete but the
> IDLE task still appears in my stack dump (or CPU usage dump). Is it normal
> ? Is there a way to "refresh" the task list.
> There is no risk that my IDLE task could be called since I have a higher
> priority task which is looping forever in my design, but it is just to make
> it a bit cleaner and to re-use the task block occupied by the BSP's IDLE.
> Any idea ?
AFAIK, you can not delete the idle task. But you can substitute the default
IDLE task with your own with configure parameter. I do not remember it, but
if you will open the idle task code you will see it immediately.
Leon
