VERY(!) slow FTP sometimes
    Till Straumann
    strauman at slac.stanford.edu
    Thu May 15 17:52:53 UTC 2008
You should probably also say what RTEMS filesystem the files
you are up/down-loading are residing on, how big they are
etc.
Also, you want to make sure the duplex settings are right
on both sides.
T.
Leon Pollak wrote:
> Hello, all.
> I incorporated the RTEMS ftpd to my MPC8247 at 150MHz based board with 100BT FCC
> controller and made several main tests - everything seems to work fine. I can
> upload/download files by Linux ftp client, FireFox in Linux and IE in
> Windows.
> Now, when I decided to test the speed, I encountered the following VERY
> strange numbers:
> 1. IE as a client: in 100% of attempts the speed was about 14-16 KB/s.
> 2. FireFox(Linux) as a client:
> 	- in 90% of attempts the speed was about 400-460KB/s
> 	- in about 10% - 7-8 KB/s.
> Even in the "good" FireFox tests (above 400KB/s) the behavior looks also
> strange a bit: it immediately starts at some number (once at 410KB/s, then at
> 450KB/s, etc...) and does not change never more.
> 1. What may be the cause of the VERY low speed cases?
> 2. Is the "good" speed really good for my case? Can somebody provide numbers
> from his/her experience?
> Thanks.
