Announcement: New version of C-Code generator from UML state charts
Peter Mueller peter.o.mueller at gmx.de
Sat Nov 22 20:14:34 UTC 2008
Hello list readers,
a new version of the SinelaboreRT codegenerator is available for
download.
SinelaboreRT generates C-Code from UML state charts.
The UML state charts can be designed with the Cadifra
UML editor, Enterprise Architect or Magic Draw.
The generation process can be widely adjusted to your needs.
sinelaboreRT was built especially with embedded real-time systems in
mind. Here are some of the main features:
Key Features:
- Generates human readable C-code
- Code generation especially for embedded real-time systems
- Supporting hierarchical designs
- No run-time environment needed
- Fits well in different system designs (foreground/background, RTOS-
based ...)
- No gap between design and code
- Support for different input formats (Cadifra, XMI)
- Simple integration in different development environments
- Low cost
- Support for automatic test-case generation
If you want to give it a try please visit www.sinelabore.com and take
a look in the manual. A demo version is also available.
With best regards,
Peter Mueller
Peter Mueller
info at sinelabore.com
www.sinelabore.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20081122/7f3b719f/attachment.html>
