libi2c register bus follow up
    Bassem Fahmy
    t_fahmy_bassem at hotmail.com
    Wed Oct 29 03:46:13 UTC 2008
i was trying to register an i2c driver to the libi2c and it was falling when checking for the /dev/i2c node. finally i used the define
CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM, which should enable the whole IMFS filesystem. after that it seem to be working ok.
now, my understanding is that we need only the Mini IMFS to get the driver nodes to work. does libi2c really need the full IMFS to work or i have some thing else wrong?
Thanks,
Bassem
_________________________________________________________________
When your life is on the go—take your life with you.
http://clk.atdmt.com/MRT/go/115298558/direct/01/
