libi2c register bus follow up
Thomas Dörfler Thomas.Doerfler at embedded-brains.de
Wed Oct 29 09:20:53 UTC 2008
Hi,
since libi2c generates device nodes dynamically (and not only based on
the device table), you need the "big" IMFS when using the libi2c.
wkr,
Thomas.
Bassem Fahmy wrote:
> i was trying to register an i2c driver to the libi2c and it was falling when checking for the /dev/i2c node. finally i used the define
> CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM, which should enable the whole IMFS filesystem. after that it seem to be working ok.
> now, my understanding is that we need only the Mini IMFS to get the driver nodes to work. does libi2c really need the full IMFS to work or i have some thing else wrong?
> Thanks,
> Bassem
> _________________________________________________________________
> When your life is on the go—take your life with you.
> http://clk.atdmt.com/MRT/go/115298558/direct/01/
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
