mvme167 help request
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Sep 11 16:01:19 UTC 2008
Chris Johns wrote:
> Joel Sherrill wrote:
>> Hi,
>> I am resurrecting a donated mvme167 system
>> for the RTEMS lab and have some issues. When
>> it boots, the board prints this:
>> WARNING: Configuration Data Failure (Invoke 'ENV' Command)
>> WARNING: Board Configuration Data Failure
>> Any suggestions on that? Is there a battery that
>> needs to be replaced. The date on the board is
>> MVME167 Debugger/Diagnostics Release Version 1.4 - 07/22/92
> There is a battery and NVRAM. The ENV command is used to control his. This is
> documented in the 167bug.pdf manual:
> http://www.ing.iac.es/~docs/external/vme/167bug.pdf
Thanks. The original RTEMS BSP was the mvme135/136 so for
better or worse, I still remember Bug. We debugged RTEMS for
years in assembly language using that. :)
Some people answered privately so I want to follow up publicly.
+ It appears that the "ST MK48T08B-15 Timekeeper" needs to
be replaced. We have two MVME167C boards and this part
is the same and dead in both. I am not sure but I think this
was the 150 nanosecond part variant and I think this MAY
be a replacement. Could someone confirm that?
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=497-2829-5-ND
Hopefully someone can confirm that the above is what I want
so I can order it.
+ The transition module was a MVME712C BUT that turns out to
probably not be a problem. (see Note 1) I realized we had another
VME system (remains of a black Motorola UNIX box) with an MVME167 \
in it along with the transition module for RJ-45 Ethernet. We will just
need to build one of those RJ serial console cables for it. I have
the one we are using with the MVME162 so I can test it first.
So I think the transition module is not an issue.
Note 1: We have a few discarded VME systems that I am nearly through
cannibalizing and adding to the lab. It looks like there will be two
empty cages if someone has a PowerPC VME board that HAS a BSP
and works they would like to send us. :)
>> If I get past that, then the 712 transition module
>> has coax for Ethernet. We have 15-pin to RJ45 transceivers
>> and coax to 15 pin but the 15 pins are obviously the
>> same sex (male) so we can't connect them in series
>> to get to RJ-45. This is a dinosaur. Does someone
>> have the part in their desk drawer? Or a URL to point
>> me to. :-D
> The 15 pin connector will be an AUI interface so you can use something like
> these AUI to RJ45 converters:
> http://www.pacificcable.com/Picture_Page.asp?DataName=KT-10T
> I think coaxial is just another level of complexity to fail at some later stage.
This makes me glad I found the other transition module. :-D
Chris .. did you get a chance to try the MVME162?
> Regards
> Chris
