network based console?
Thomas Doerfler (nt) Thomas.Doerfler at imd-systems.de
Fri Sep 12 19:23:16 UTC 2008
Hi,
just to throw in my two cents: wouldn't it be possible to establish the
pseudo-tty driver as "console" replacement? Iam sure this needs some
tinkering, but might be worth a try.
Thomas.
Till Straumann schrieb:
> If you want to redirect your system console to a TCP/IP socket
> then you have to consider a few gotchas:
>  - 'printk' will never be possible; printk normally uses a polling
>    driver for the serial port enabling it to be called everywhere
>    (w/o task context, from an ISR, before system is up etc.).
>    Unless you have a second networking
>    IF and implement a special polling driver + protocol stack there
>    you're not going to have printk.
>  - you should be able to replace fds 0,1,2 with a TCP socket so
>    that all stdio goes over that connection.
>  - HOWEVER: the RTEMS file-system per se is not thread-safe
>    and RTEMS sockets are not. Therefore, you'd need to somehow
>    add locking; so you'd probably have to write a small 'driver'
>    wrapping a mutex lock/unlock pair around read/write from/to
>    the socket.
>  - NOTE: RTEMS/newlib's FILE buffers are global, unprotected
>    objects and sharing them among threads is not safe (unless
>    you add locking yourself).
>    BUT: the stdin/stdout/stderr streams/buffers are
>    exceptional: every thread has it's own set of 3 buffers (all
>    sharing the underlying file descriptors 0,1,2).
> HTH
> -- Till
> Gene Smith wrote:
>> Right now my stdin and stdout operations go in/out the serial port.
>> However, my serial port *must* go away since it is multiplexed with a
>> more essential function that replaces it. However, my ethernet tcp/ip is
>> working well now. Is it possible to setup a remote terminal using tcp/ip
>> that will act as stdin/stdout for my board running rtems? This would
>> mainly be for debug or control purposes and probably not kept in the
>> final version.
>> In the past, I have used syslog to record debug messages on a remote
>> system (output only) via UDP. I see mention of a telnetd for rtems that
>> might allow me to connect to the rtems board but not sure that the
>> remote telnet terminal functions the same as the remote serial terminal
>> (ie, gtkterm, minicom, etc), i.e., printf's output to it and keystroke
>> are input back to rtems.
>> I expect this is all bound in with termios and the console driver and
>> network driver but not sure how it all ties together or if what I want
>> is possible. I will keep looking. But any advance information or
>> comments would be appreciated.
>> -gene
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
