linux/posix port compiling problem
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 15 19:30:14 UTC 2009
Wei-Tsun Sun wrote:
> Hi,
> Sorry for the late reply.
> On Tue, 14 Apr 2009 16:45:20 +0200
> Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>> Joel Sherrill wrote:
>>> Looking at the patch, it looks like it boils down to 3 things:
>>> + disable shell for posix port (easier to drop it from building at all).
>> Well, rtems shell got infected with with newlib-proprietary,
>> non-portable construct.
> I am not very familiar with libmisc yet, but `shell` looks an important thing to me, or it does not look like its name to be...as a proper shell ?
It is a small but more or less proper shell. The issue it not
with the code you are trying to compile. But the fact that the
unix port is to a "synthetic" target -- not real hardware. It is
using the native unix libc. Much of RTEMS is not buildable in
this environment -- including the shell, BSD TCP/IP stack and the
entire POSIX thread interface.
If you want a more proper RTEMS experience switch to
a real port (e.g. i386-rtems4.10) and run the RTEMS executables
on a simulator or real hardware.
>> IMO, we should get rid of them and either re-write the code or abandon it.
>>> + use *.o on command line instead of from file with ar (why?)
>> IMO, this patch doesn't make much sense.
> When I built rtems, sometimes rel files were not generated for some wrapups, and "ls" generated an error code which stopped the building process
> due to "file (*.rel) not found".
>>> + a small patch to provide a malloc initialize stub.
>> This is a real bug in RTEMS.
>> Ralf
