mvme6100 support
Fri Jul 17 02:19:36 UTC 2009
Feng, Kate wrote:
> I wrote and upgraded the mvme5500 BSP to disco BSP to support the
> mvme6100 board.  At that time, the performance of the network on
> the mvme6100 board was not important, but the decision for the
> choice of H/W for my project was urgent.  Thus, the code for
> the network is not really ready for a formal release yet.  It seems that the
> network code for beatnik BSP needs to be  optimized or rewritten  as well
> based on the version I obtained from Till Straumann a while ago.
> I do not know if he had any chance to improve the netowrk
> performance ever since then.
So .. it should work to ...
a) build for mvme5500 and run on mvme6100?
b) add alias to build for mvme6100 and fix x odd
     issues for mvme6100
Does this mean the network driver works?  How
bad is "not optimized" really?
Just asking because I know you are a perfectionist and
wanted to get an accurate description of the status. :)
--joel
> At this point, I have at least two other higher priority tasks to be
> completed before I have a chance to  finish rewriting the network
> code for the mvme6100 board to boost up its performance, although it
> could be a fun project.
> Cheers,
> Kate
> ________________________________
> From: rtems-users-bounces at rtems.org on behalf of Daron Chabot
> Sent: Thu 7/16/2009 9:25 PM
> To: RTEMS
> Subject: mvme6100 support
> Just looking at the cvs HEAD, it seems as though the mvme5500 bsp may
> also support the mvme6100 board. Is this correct ?
> Or should I instead be inquiring about the "beatnik" bsp for 6100 support ?
> Thanks.
> -- dc
> rtems-users mailing list
> rtems-users at rtems.org
