mvme6100 support
Kate Feng
feng1 at bnl.gov
Fri Jul 17 11:06:25 UTC 2009
Joel Sherrill wrote:
> Feng, Kate wrote:
>> I wrote and upgraded the mvme5500 BSP to disco BSP to support the
>> mvme6100 board. At that time, the performance of the network on
>> the mvme6100 board was not important, but the decision for the
>> choice of H/W for my project was urgent. Thus, the code for
>> the network is not really ready for a formal release yet. It seems
>> that the
>> network code for beatnik BSP needs to be optimized or rewritten as
>> well
>> based on the version I obtained from Till Straumann a while ago. I
>> do not know if he had any chance to improve the netowrk
>> performance ever since then.
> So .. it should work to ...
> a) build for mvme5500 and run on mvme6100?
Not the mvme5500 BSP in the current RTEMS release.
I could rename "disco" BSP back to "mvme5500" BSP
for the RTEMS release, except the network driver was/is
really not ready for the open release yet.
> b) add alias to build for mvme6100 and fix x odd
> issues for mvme6100
> Does this mean the network driver works? How
> bad is "not optimized" really?
Yes, the network driver for the mvme6100 works, at
least for the one project I tested, but a workaround that
have degraded the actual performance of the H/W by my
estimation of at least two.
It was not written for the real-time performance because
there were somethings missing. I had to quickly move on
to a different H/W platform because the DDR memory
date rate is too slow for my project, not because of the
network driver. I actually started to rewrite the driver to
meet the requirement of the real-time programming.
However, it kept getting interrupted by my other higher
priority projects that I could not get this project
completed. It should be fun to get it finished, but
it is more important to get my other projects done at
this point.
Regards,
Kate
> Just asking because I know you are a perfectionist and
> wanted to get an accurate description of the status. :)
> --joel
>> At this point, I have at least two other higher priority tasks to be
>> completed before I have a chance to finish rewriting the network
>> code for the mvme6100 board to boost up its performance, although it
>> could be a fun project.
>> Cheers,
>> Kate
>> ________________________________
>> From: rtems-users-bounces at rtems.org on behalf of Daron Chabot
>> Sent: Thu 7/16/2009 9:25 PM
>> To: RTEMS
>> Subject: mvme6100 support
>> Just looking at the cvs HEAD, it seems as though the mvme5500 bsp may
>> also support the mvme6100 board. Is this correct ?
>> Or should I instead be inquiring about the "beatnik" bsp for 6100
>> support ?
>> Thanks.
>> -- dc
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
