Integrating Micromonitor Support Into RTEMS
Leon Pollak
leonp at plris.com
Thu Jun 11 18:31:20 UTC 2009
Here, at PLR, we happily use Micromonitor for years to run RTEMS.
We did a BSPs called uMon_8260 and uMon860 which actually do wrapping the
console to uMon and include Ethernet driver.
That is...:-)
Thanks a lot to Ed Sutter.
On Thursday June 11 2009, Joel Sherrill wrote:
> Hi,
> I am close to having the Micromonitor application
> support code working completely with RTEMS. This
> includes the "monlib" functionality which allows
> you to utilize a LOT of functionality provided by
> the monitor as well as Ed Sutter's "TFS RTEMS
> Filesystem". Micromonitor has its own file system
> and his TFS filesystem allows you to mount this
> and access it via monitor support.
> The code will obviously only work on boards with
> Micromonitor but since Micromonitor supports
> many boards across multiple architectures and this
> code is BSP independent, I am feeling a tug to
> put it into CPU Kit since it only requires 1 BSP
> method to support it.
> The alternative is to put it in libbsp/shared and
> make every BSP that wants to use it, add rules to
> their Makefile.am.
> Any suggestions? Thoughts?
Dr.Leon M.Pollak
Director
PLR Information Systems Ltd.
Tel.:+972-98657670 | POB 8130, H'Aomanut 9,
Fax.:+972-98657621 | Poleg Industrial Zone,
Mob.:+972-544739246 | Netanya, 42160, Israel.
