Microseconds per tick
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Fri Mar 27 09:38:38 UTC 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Leonard,
obviously you are a bit confused by the term "tick". In this
configuration option, a "tick" is the interval between two increments of
the RTEMS-maintained system time.
What you are refering to is the (similar, but different) option
CONFIGURE_CLICKS_PER_MICROSECOND
which defines, how often the HW timer (which generates the system tick
interrupts) is increment per microseconds.
Without knowing the LEON, I would say that if the HW timer is
incremented with 80MHz, you should set CONFIGURE_CLICKS_PER_MICROSECOND
to 80.
And you might set CONFIGURE_MICROSECONDS_PER_TICK to 1000 to get a
system tick/time granularity of 1000us = 1ms.
wkr,
Thomas.
Leonard Bise wrote:
> Hi all,
> I'm quite new to RTEMS and I'm not very experienced so I hope you can
> give me an hand!
> We are working with a board using a LEON2 Sparc processor running at
> 80Mhz, I figured that the microseconds per tick value would be 0.0125
> (is this correct?).
> Shall I simply configure my application with this define ? #define
> CONFIGURE_MICROSECONDS_PER_TICK 0.0125 ?
> I hope you can help, thanks in advance.
> Léonard.
> ps: By the way I posted once using the wrong mail address and it said it
> was awaiting approval from the moderators, please delete this one. This
> is the correct address.
> rtems-users mailing list
> rtems-users at rtems.com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFJzJ6bwHyg4bDtfjQRAlT3AJ9VZ9bIgWWmDFgKfzbSRpplNC2QIACgiqyL
/pRCk4kE/PpTPPauwEVOwXM=
=ZxD9
-----END PGP SIGNATURE-----
