Ignore: Re: Microseconds per tick
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Fri Mar 27 09:47:10 UTC 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Leonard,
ups, obviously  I was completely on the wrong track. Please forget my
previous answer..
Time for the weekend :-(
Thomas.
Thomas Doerfler wrote:
> Leonard,
> obviously you are a bit confused by the term "tick". In this
> configuration option, a "tick" is the interval between two increments of
> the RTEMS-maintained system time.
> What you are refering to is the (similar, but different) option
> CONFIGURE_CLICKS_PER_MICROSECOND
> which defines, how often the HW timer (which generates the system tick
> interrupts) is increment per microseconds.
> Without knowing the LEON, I would say that if the HW timer is
> incremented with 80MHz, you should set CONFIGURE_CLICKS_PER_MICROSECOND
> to 80.
> And you might set CONFIGURE_MICROSECONDS_PER_TICK to 1000 to get a
> system tick/time granularity of 1000us = 1ms.
> wkr,
> Thomas.
> Leonard Bise wrote:
>> Hi all,
>> I'm quite new to RTEMS and I'm not very experienced so I hope you can
>> give me an hand!
>> We are working with a board using a LEON2 Sparc processor running at
>> 80Mhz, I figured that the microseconds per tick value would be 0.0125
>> (is this correct?).
>> Shall I simply configure my application with this define ? #define
>> CONFIGURE_MICROSECONDS_PER_TICK 0.0125 ?
>> I hope you can help, thanks in advance.
>> Léonard.
>> ps: By the way I posted once using the wrong mail address and it said it
>> was awaiting approval from the moderators, please delete this one. This
>> is the correct address.
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.3 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFJzKCdwHyg4bDtfjQRAlnGAJ0WZe4E5EKI4uHPr66k80Cvi3SFowCgmN5O
McqixtoLiyUBPlSyJjaQOso=
=zUhK
-----END PGP SIGNATURE-----
