How to properly add a new bsp
Andrei Chichak
groups at chichak.ca
Tue Sep 8 18:59:28 UTC 2009
I've run into this a couple of times now - I want to add a BSP that is
derived from an existing one.
QUESTION: What files should I munge and which commands do I use to let
RTEMS know that the new BSP exists so that I can install it?
I install all of the tools on windows (using MSYS and MinGW), put the
distribution into place, make a copy of the BSP with a new name, then...
../rtems-4.9.1/configure --target=m68k-rtems4.9 --enable-
rtemsbsp=cml5282
make install
The installer goes through the motions but terminates with Nothing to
be done. If I use an existing bsp it works great.
Thanks,
Andrei
Andrei Chichak
Systems Developer
CBF Systems Inc.
4-038 NINT Innovation Centre
11421 Saskatchewan Drive
Edmonton, Alberta
T6G 2M9
Phone: 780-628-2072
Skype: andrei.chichak
