How to properly add a new bsp
Andrei Chichak groups at chichak.ca
Wed Sep 9 03:48:54 UTC 2009
Yes, it absolutely helped.
Thank you very much.
Andrei
On 2009-September-08, at 3:40 PM, Daron Chabot wrote:
> You'll need a couple of things to get going:
> 1) take a look at c/lib/libbsp/m68k/acinclude.m4. You'll need to add
> an entry here for your BSP. Initially, just copy an existing BSP and
> rename it.
> 2) add a file (*.cfg) to make/custom for your new BSP. Again, just
> copy + rename an existing one.
> 3) re-run "bootstrap" to generate the appropriate auto-tools files
> HTH
> -- dc
> On Tue, Sep 8, 2009 at 2:59 PM, Andrei Chichak<groups at chichak.ca>
> wrote:
>> I've run into this a couple of times now - I want to add a BSP that
>> is
>> derived from an existing one.
>> QUESTION: What files should I munge and which commands do I use to
>> let RTEMS
>> know that the new BSP exists so that I can install it?
>> I install all of the tools on windows (using MSYS and MinGW), put the
>> distribution into place, make a copy of the BSP with a new name,
>> then...
>> ../rtems-4.9.1/configure --target=m68k-rtems4.9 --enable-
>> rtemsbsp=cml5282
>> make install
>> The installer goes through the motions but terminates with Nothing
>> to be
>> done. If I use an existing bsp it works great.
>> Thanks,
>> Andrei
>> Andrei Chichak
>> Systems Developer
>> CBF Systems Inc.
>> 4-038 NINT Innovation Centre
>> 11421 Saskatchewan Drive
>> Edmonton, Alberta
>> T6G 2M9
>> Phone: 780-628-2072
>> Skype: andrei.chichak
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Andrei Chichak
Systems Developer
CBF Systems Inc.
Edmonton, Alberta
T6G 2M9
Phone: 780-628-2072
