FTP client API
Arnout Vandecappelle
arnout at mind.be
Tue Apr 27 11:08:10 UTC 2010
On Monday 26 April 2010 18:46:51, Thomas Doerfler (nt) wrote:
> By the way: I have written the original FTPFS implementation. I found it
> quite useful that I don't have to copy a file to the RTEMS system when
> processing it. Out of curiousity: Which functionality are you really
> missing in FTPFS, so you have to implement a different package?
My use case is that from a custom shell I want to copy files to/from an FTP
server. FTPFS is fine as such, except that it is awkward to compose a
string to specify server, username and password, which is then parsed again
by the ftpfs.
The ftplib that Leon pointed out is in that sense slightly easier to use
than ftpfs, so I'm using that now.
Regards,
Arnout
Arnout Vandecappelle arnout at mind be
Senior Embedded Software Architect +32-16-286540
Essensium/Mind http://www.mind.be
G.Geenslaan 9, 3001 Leuven, Belgium BE 872 984 063 RPR Leuven
LinkedIn profile: http://www.linkedin.com/in/arnoutvandecappelle
GPG fingerprint: 31BB CF53 8660 6F88 345D 54CC A836 5879 20D7 CF43
