GeSys on a mvme167?
Till Straumann strauman at slac.stanford.edu
Fri Jul 23 07:41:31 UTC 2010
Sorry it took so long to respond.
The GeSys and especially the binaries are unfortunately very old. I just
don't have
the time to maintain these.
I uploaded a current snapshot of GeSys including cexp. I had tested this
software on
the mvme167 successfully albeit not recently.
The build system is now gnu configure based - read 'INSTALL' for
instructions.
The sources are available from
http://www.slac.stanford.edu/~strauman/rtems/software.html
HTH
-- Till
PS: Note that you have to tweak the EPICS build system if you want
to build run-time loadable EPICS applications. I can give you more
information
once you need it...
On 07/20/2010 05:58 PM, Jan C. Bernauer wrote:
>  Hi,
>  the latest source for GeSys I can find is 2.1beta (from Till's
> homepage), which claims to not support mvme167.
> However, the RTEMS evaluation CD seems to include a binary for that
> board. Is there newer source available somewhere?
> My board has 16 Megs of RAM, so GeSys might be useful as a loader for
> Epics.
> Best regards,
> Jan
> rtems-users mailing list
> rtems-users at rtems.org
