sh architecture, "hello" sample doesn't work
Alberico Colpo
alberico at acquacontrol.it
Tue Jun 29 14:16:53 UTC 2010
martedì 29 giugno 2010, 15:47 ha scritto:
> Hi Alberico,
> >> I remember i enabled the redefinition of CONSOLE_DRIVER_TABLE_ENTRY in
bsp.h.
> Thanks! This almost worked. However it only seems to apply to rtems 4.9;
> in 4.10, this redefinition is not there to be enabled, and when I
> copy/pasted it in, it still did not work.
> With rtems 4.9, when I tried this, SCI0 spit out some garbled
> characters; using the debugger to step up to just before starting the
> user application, I checked that the baud rate register was what I
> expected, so I know I shouldn't have the baud rate incorrect here...
You probably already checked, but , is also the parity correct?
> Also, the readme leads me to believe that gdb should receive a message
> after exit from the rtems application, but it never gets there; in fact
> the gdb stub at this point stops responding, and the chip needs to be
> reset. This suggests to me that either the gdb stub is hanging up, or
> rtems has modified the baud rate or something else related to SCI1 after
> running the application.
> Getting closer, though!
> Cheers,
> Steve
I cc mailing list may we get more help..
Well, after the hello.exe test I rewrote the console driver:
having only 2 SCI, I'm using SCI1 for both as console and debug port, so I
have all the console io functions inside the BSP path.
I'm not aware of the changes in console driver for rtems-4.10 (still working
on 4.9).
Anyway, I'm still having some problems (i think mostly configuration problems)
in getting the termios driver to use the interrupt driven functions.
I think your debugger hang because the startup code of rtems will reassign the
vector table, you need to replace the stub traps (at least 32, 33 , 34 and
NMI) before the change of VBR occurs.
Alberico Colpo
acquacontrol automazioni s.r.l.
Via 2.a strada 151 ZI
Tel. 0444673084 Fax. 0444673798
36071 Arzignano (VI)
** Le informazioni contenute nella presente e-mail sono confidenziali e sono
intese per il solo utilizzo da parte del destinatario sopra indicato. Le
informazioni potrebbero essere soggette a vincoli di riservatezza ai sensi
delle leggi applicabili. Chiunque riceva la presente e-mail non essendone il
destinatario, � avvisato che qualunque utilizzo o riproduzione di tale e-mail
� vietata. Se ricevete questa e-mail erroneamente, vogliate cortesemente
avvisarci immediatamente.
This message is for the designed recipient only and may contain privileged,
proprietary , or otherwise private imformation. If you have received it in
error , please notify the sender immediately and delete the original . Any
other unauthorized use of this e-mail by you is prohibited **
