VirtualBOX + gPXE> imgload rtems.exe --> Invalid argument (0x1c838002)
Gedare Bloom
gedare at gwmail.gwu.edu
Thu Oct 28 15:20:57 UTC 2010
Did you try to follow the instructions on the Wiki?
http://www.rtems.com/wiki/index.php/RTEMS_on_Virtualbox
These steps worked for RTEMS 4.10. I'm not sure about your version of gPXE,
or about RTEMS 4.8.
Good luck,
Gedare
On Thu, Oct 28, 2010 at 7:37 AM, Евгений Савенко <savenkoeugene at gmail.com>wrote:
> Hello all.
> I'm trying to run my the RTEMS project in VirtualBox where I use the
> gPXE as boot-loader that is run from virtual floppy disk. The gPXE
> fetches the executable rtems.exe successful but the imgload command
> returns “Invalid argument (0x1c838002)”.
> gPXE> imgfetch tftp://10.0.2.2/rtems.exe
> imgfetch tftp://10.0.2.2/rtems.exe . ok
> gPXE> imgstat
> rtems.exe: 1187864 bytes “” <-- ! correct size !
> Could not load rtems.exe: Invalid argument (0x1c838002)
> I use Linux Debian/lenny as a development platform and the RTEMS
> release-4.8. Build my project in IDE Eclipse + CDT RTEMS plug-in no
> errors no warnings. Resulting executable rtems.exe I'm trying to
> load.
> May by the gPXE doesn’t my executable format?
> Are anybody faced with that problem or similar?
> Thanks for any help.
> Best regards,
> Eugene Savenko.
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20101028/a229149b/attachment-0001.html>
