Confused about 4.10 branch
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Wed Feb 16 20:52:32 UTC 2011
On 02/16/2011 12:47 PM, Peter Dufault wrote:
> I'd been fetching and using what had been "4.9.99.0" (I haven't updated in a while) and just tried to use 4.10.  But this fix in cpukit/score/cpu/powerpc/rtems/powerpc/registers.h:
In a CVS/ directory is there a Tag file?  If not, it is just an old
checkout from the head.
If it is, then it is just before the number was changed.  I had
to change the version number just before cutting 4.10.0
> revision 1.30
> date: 2010/06/30 07:43:00;  author: sh;  state: Exp;  lines: +17 -17
> 2010-06-30	Peter Dufault<dufault at hda.com>
> 	PR 1588/cpukit
> 	* rtems/powerpc/registers.h: Renamed defines SR0 .. SR15 in
> 	PPC_SR0 ..  PPC_SR15.
What file is this?   You can always use the graphical tree view
like this to see what's happened and when a file branched:
http://www.rtems.org/viewvc/rtems/c/src/lib/libbsp/powerpc/gen5200/ChangeLog?view=graph
> from last June isn't in 4.10, 4.10 picks up at 1.29:
>   	rtems-4-10-0: 1.29
> Why isn't that fix in 4.10?  When was 4.10 split off from the head?
June 2010 according to the Wiki
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
