Rate monotonic help
Matthews, Lee l.matthews at imperial.ac.uk
Mon Jul 25 17:44:14 UTC 2011
Hi
I'm developing some software that uses RTEMS on an Aeroflex Gaisler LEON3 processor that is running on a Pender GR-CPCI-AX2000 development board.
I'd like to setup a task that is called 122 times per second. I'm currently trying to use the rtems rate_monotonic functions but I'm not having much luck.
I have used the example code from the rtems_user_guide as a guide.
My function looks like the following :
rtems_task Periodic_task()
      rtems_name name;
      rtems_id period;
      rtems_status_code status;
      unsigned int flag=0;
      unsigned long count=0;
      unsigned int i=0;
      printf( "Starting periodic function : 61Hz clock output.\n");
      printf( "Turning GPIO OFF.\n");
      gpiolib_set(port1,1,0); // Set GPIO0 to OFF
      for(count=0;count<1000000;count++) {}
      printf( "Exiting wait loop.\n");
      name = rtems_build_name( 'P', 'E', 'R', 'D' );
      status = rtems_rate_monotonic_create( name, &period );
      if ( status != RTEMS_SUCCESSFUL ) {
            printf( "rtems_monotonic_create failed with status of %d.\n", status );
            exit( 1 );
      while ( 1 ) // RTEMS ticks per second set to 122.
            if ( rtems_rate_monotonic_period( period, 1 ) == RTEMS_TIMEOUT )  break;
            /* Perform some periodic actions */
            if(flag==0)
                  gpiolib_set(port1,1,1); // Set GPIO0 to ON
                  flag=1;
            else
                  flag=0;
      /* missed period so delete period and SELF */
      status = rtems_rate_monotonic_delete( period );
            printf( "rate_monotonic_delete failed with status of %d.\n", status );
            exit( 1 );
      status = rtems_task_delete( RTEMS_SELF );
      /* should not return */
      printf( "rtems_task_delete returned with status of %d.\n", status );
      exit(1);
I'd like for the function to turn one of the GPIO lines on and off repeatedly, but all that seems to happen is that the code within the while ( 1 ) loop executes once, then stops.
The code that I use to create and start this task is the following :
Task_name1 = rtems_build_name( 'P', 'E', 'R', 'D' ); // Set task name to 'PERD'
                status = rtems_task_create(Task_name1, 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,RTEMS_DEFAULT_ATTRIBUTES, &Task_id1);
                if(status!=RTEMS_SUCCESSFUL)
                                printf("rtems_task_create unsuccesful\n");
                                exit( 0 ); // Exit
                else
                                printf("Created Periodic task\n");
                status = rtems_task_start( Task_id1, Periodic_task, 1 ); // Start Periodic task
                                printf("rtems_task_start unsuccesful\n");
                                exit( 0 ); // Exit
Could anyone shed some light on what I'm doing wrong please?
Thanks in advance,
Lee
URL: <http://lists.rtems.org/pipermail/users/attachments/20110725/02d89894/attachment.html>
