Various libs ported to RTEMS
Sebastien Bourdeauducq
sebastien at milkymist.org
Wed May 4 10:17:08 UTC 2011
Hi,
I recently got several 'standard' libraries to work under RTEMS:
* libgd (image manipulation)
* libcurl (network client library for HTTP and many other protocols)
* expat (XML parser)
* libconfig (configuration file management)
* openjpeg (JPEG2000)
* jbig2dec (JBIG2, a B&W image format)
* mupdf (PDF rendering)
If you are interested in them, some build instructions are available at:
http://www.milkymist.org/wiki/index.php?title=Flickernoise_build_instructions
So far, the only major problem that I have noticed is that timeouts do
not work in libcurl (CURLOPT_CONNECTTIMEOUT and CURLOPT_TIMEOUT).
S.
