Issue in blackfin toolchain
Rohan Kangralkar
rohankangralkar at yahoo.com
Tue May 24 15:39:02 UTC 2011
Hi,
I am not using the ADI toolchain. I am using the toolchain provided by rtems.
*I compile my source using** bfin-rtems4.11-gcc. Then i load it
to bfin-rtems4.11-gdb and** connect it to the bfin simulator.
**Then i try to put a breakpoint in the file by opening then file.
**The debugger complains that there is no such line number. Also
**there is no optimization set while compiling. I also compile with
the -g flag so that the debug symbols are included.** This is making
my debugging difficult since i have to look at the** disassembly
for debugging. Is there any way i can use the C** source for debugging.*
I find only the RTEMS Tool Test Results
<http://www.rtems.org/pipermail/rtems-tooltestresults/> mailing group
on rtems. To which
group should i move this thread to.
Rohan Kangralkar
Sorry I lost the mailing thread so i had to copy the mail contents.
Unfortunately, we probably need to move this to either the
binutils or gdb mailing lists. I am not sure which. Probably
the gdb mailing list is more likely to produce an answer.
Just to make sure I understand the bfin-elf gdb configuration
includes support for a debug connection to a target that
bfin-rtems does not? That doesn't seem correct given
that bfin-*-* is the pattern which matches both rtems
and elf bfin targets in gdb/configure.tgt
And the gdb's are built from the same source tree?
Why do you need the bfin-elf toolchain at all?
--joel
On 05/18/2011 10:55 AM, Rohan Kangralkar wrote:
*>* On Wed, May 18, 2011 at 11:44 AM, Rohan Kangralkar
*>* <rohan.stays at gmail.com
<http://www.rtems.org/mailman/listinfo/rtems-users>
<mailto:rohan.stays at gmail.com
<http://www.rtems.org/mailman/listinfo/rtems-users>>> wrote:
*>* On Thu, May 12, 2011 at 5:43 PM, Joel Sherrill
*>* <joel.sherrill at oarcorp.com
<mailto:joel.sherrill at oarcorp.com
*>* On 05/12/2011 04:41 PM, Rohan Kangralkar wrote:
*>* Hi,
*>* I am using the rtems blackfin tools to build and debug my
*>* board that contains analog devices BF527 processor.
*>* The issue i am facing is that I am not able to place
*>* breakpoints in some part of my c code. So the debugging is
*>* becoming difficult. GDB complains "No line 291 in file"
*>* even though the file has more that 300 lines of code.
*>* What's the name of the file? There is a chance there are two
*>* files with the same name in the executable and gdb is confused.
*>* I have seen this before.
*>* The name of the file is tll_fpga.c. I looked for the file in my
*>* project and there are no files with duplicate file names.
*>* I use the compiler, debugger provided by rtems4.11 for
*>* debugging my application.
*>* After some debugging and analysis of the mapping the line
*>* number in the elf to the C code in the file using objdump
*>* i find the following.
*>* 1. executing the bfin-elf-objdump ( analog devices
*>* toolchain) on the elf the following error is thrown out
*>* BFD: Dwarf Error: mangled line number section.
*>* 2. but the objdump from rtems does not complain.
*>* Are they built from the same source? If not, then random
*>* differences.
*>* They are built from the same source.
*>* So
*>* How do i correct the issue in the rtems blackfin gdb?
*>* I also observe that analog devices have their own
*>* gdb-proxy but rtems does not provide gpd-proxy
*>* should the gdb-proxy also be included in the rtems bfin
*>* toolchain?
*>* Would be good. Yes.
*>* I have some more information about the problem. To decouple it
*>* from the ADI toolchain, I compile my source using
*>* bfin-rtems4.11-gcc. Then i load it to bfin-rtems4.11-gdb and
*>* connect it to the gdb bfin simulator.
*>* Then i try to put a breakpoint in the file by opening then file.
*>* The debugger complains that there is no such line number. Also
*>* there is no optimization set while compiling.
*>* This is making my debugging difficult since i have to look at the
*>* disassembly for debugging. Is there any way i can use the C
*>* source for debugging.
*>* Thankyou
*>* Rohan Kangralkar
*>* Joel Sherrill, Ph.D. Director of Research&
*>* Development
*>* joel.sherrill at OARcorp.com
<http://www.rtems.org/mailman/listinfo/rtems-users> On-Line
Applications Research
*>* Ask me about RTEMS: a free RTOS Huntsville AL 35805
*>* Support Available (256) 722-9985 <tel:%28256%29%20722-9985>
*>* ___________________________
*>* Thanks and regards
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20110524/d98053c6/attachment.html>
