Target Device
Cláudio Silva claudiodcsilva at gmail.com
Thu May 26 20:40:26 UTC 2011
Hello,
Assuming that you have built and installed RTEMS correctly you can
follow the instructions on the Getting Started Guide:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/started/started00062.html
You can build the sample applications available in the CVS. For that
you must checkout "examples-v2" from the RTEMS CVS:
cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P examples-v2
Also you must export the  RTEMS_MAKEFILE_PATH variable on your
environment. Assuming that you did not change the path were you
installed RTEMS:
export RTEMS_MAKEFILE_PATH=/opt/rtems-4.10/i386-rtems4.10/pc386/ (or
any other BSP you have installed: e.g. pc586)
Then you just have to change directory to examples-v2 and issue make.
The several examples should build and produce executables. Finally you
can run those .exe using qemu[1], virtualbox[2] or even your own PC:
[1] http://wiki.rtems.org/wiki/index.php/QEMU
[2] http://wiki.rtems.org/wiki/index.php/RTEMS_on_Virtualbox
Cláudio Silva
2011/5/26 Eduardo LR-Informática <eduardo.bortolini at lri.com.br>:
> Hi all,
> I am trying to put RTEMS (4.10.0) system in a X86 architeture. To make it I
> installed Fedora (2.6.38.6-26.rc1.fc15.i686) and I followed the instructions
> in theses links:
> http://rtems.org/wiki/index.php/APT/Yum_Repository
> http://www.rtems.org/wiki/index.php/Quick_Start
> I compiled the code and give make and make install resulting in these
> files/folders:
> config.log
> config.status
> i386-rtems4.10
> make
> Makefile
> testsuites
> tools
> At this point I don't know how to proceed, my intention is to put the system
> in another machine (x86 architeture) to make a embedded system. Reading the
> documents I didn't find or understand what is the next step... if somebody
> could help me I would appreciate....
> Best Regards,
> Eduardo Bortolini
> Engenharia de Aplicação
> LR Informática Industrial - MATRIZ
> Rua Sergio Jungblut Dietrich, 900 pav. 26
> CEP: 91060-410 - Porto Alegre - RS - Brasil
> (  0800 704-4788
> 2 +55-51-2129-3008
> )+55 51 2129-3023
> 8 http://www.lri.com.br/
> * eduardo at lri.com.br
> rtems-users mailing list
> rtems-users at rtems.org
