run example applications
domenico.dileo at unina.it domenico.dileo at unina.it
Fri Apr 27 14:38:30 UTC 2012
Sorry Sebastian, I thought it was necessary every time we want to
compile an application. Conversely we have to run make install just once.
Thank you
Quoting Sebastian Huber <sebastian.huber at embedded-brains.de>:
> On 04/24/2012 05:42 PM, domenico.dileo at unina.it wrote:
>> If I  don't want to run the make install in rtems build directory
>> and I want to directly assign a value to these variables,
>> what should I write?
> Why do you not want to run "make install"?  You can select an
> installation prefix with "--prefix=XYZ" at the configure command
> line.  You can also use "make DESTDIR=XYZ install".
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> rtems-users mailing list
> rtems-users at rtems.org
Domenico Di Leo, PhD student, Universit? degli Studi di Napoli Federico II
Ph:     +39 081 676770
Fax:    +39 081 676574
Web: http://wpage.unina.it/domenico.dileo
