RES: RTEMS boostrap | Selective bootstrap
    Wendell Pereira da Silva
    wendell.silva at compsisnet.com.br
    Fri Feb 17 16:26:54 UTC 2012
Ralf and Sebastian.
The motivation for speed up bootstrap is an implementation of a kind of continuous integration process (I'm using Jenkins (http://jenkins-ci.org) by the way), on CentOS 6 as a server. One of its procedure is to capture all the software dependencies (RTEMS / BSP / Libs, etc) from scratch and from official sources to track the stability of the build and test execution in many configurations over time.
Thank you very much for the hints you provided, and then redefine "from scratch" in my case :-)
Wendell.
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Ralf Corsepius
Enviada em: sexta-feira, 17 de fevereiro de 2012 11:57
Para: Sebastian Huber
Cc: rtems-users at rtems.org
Assunto: Re: RTEMS boostrap | Selective bootstrap
On 02/17/2012 02:38 PM, Sebastian Huber wrote:
> On 02/17/2012 02:01 PM, Wendell Pereira da Silva wrote:
>> Hello,
>> Every time a brand new RTEMS versions is released, the bootstrap is
>> kind of annoying (it takes too long).
MinGW, I presume? Use a different OS, and you'll experience a huge difference in speed.
>> I was just wondering if a selective bootstrap would be available. For
>> example:
Unless the structure of the source-tree changes, all you've got to do is to run bootstrap once.
>> if you are going to work with sparc/leon3, network and samples, then
>> the bootstrap does not need to process unneeded (not used) things.
>> Is there any effort in this sense?
> I just use this:
> cd git-rtems/...
> ~/git-rtems/bootstrap -p ; ~/git-rtems/bootstrap -g
And even this redundant.
Just run a full bootstrap once (Or keep the autotool generated files in git - Unfortunately, git like CVS does not preserve timestamps) and "configure --enable-maintainer-mode".
This way you rarely need to run bootstrap ever.
Ralf
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
