good first target?
Mon May 14 07:04:20 UTC 2012
On 05/13/2012 07:49 PM, Patrick wrote:
>> You can develop a BSP for the LM3S8962. We already support the LM3S6965 on
>> the Qemu simulator.  You can play around with this BSP on Qemu to do your
>> first steps with Ada and learn more about the system initialization of
>> RTEMS.  You can then write step-by-step a BSP for the LM3S8962.
>   Thanks Sebastian
> This board looks very nice, I'll try to buy one.
> If I can get RTEMS onto my Luminary board I will post a tutorial on it.
Please note that this BSP runs currently only on the Qemu simulator.  The
low-level initialization (clocks, memory, pins, etc.) must be added.  You can
send patches to rtems-devel at rtems.org if you get it running.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
