Rtems-4.10.2 and RPC on PowerPC
rwas rbtwas at gmail.com
Sat Oct 20 01:15:15 UTC 2012
I have not tried to use the patch you provided.
As soon as I was reasonably sure that 4.10.x had issues (and was not my
coding) I chose to step back to 4.9.3.
At this point, my schedule is too tight to risk using 4.10.x. I would
like to help you
debug 4.10, I just can't spend the time on it now.
I do thank you for taking the time to help me on this Kate.
Robert W.
Kate Feng wrote:
>  Is there anything wrong with the patch I sent yesterday for 4.10.0 ?
>  Does it work for you in  4.10.0? We have used that code  for more
>  than a year.
>  I debugged RTEM4.10.2 today.  It seems that the main issue is not
>  related to the patch I sent or the code in RTEM4.10.2 (e.g.
>  bootcard.c), although there are some discrepancies between the two.
>  It seems that there are some bugs in the compiling tools for
>  RTEMS-4.10.2 because malloc() does not behave the same as
>  RTEMS-4.10.0 does, even though the relevant code are the same.
>  For both 4.10.0 and 4.10.2,  I used the gcc-core-4.4.6.tar.bz2 and
>  gcc-g++-4.4.6.tar.bz2.
>  However, for  RTEMS4.10.0, I applied the patch
>  gcc-core-4.4.6-rtems4.10-20110420.diff For  RTEMS4.10.2, I applied
>  the patch gcc-core-4.4.6-rtems4.10-20110829.diff, and
>  gcc-g++-4.4.6-rtems4.10-20110829.diff.
>  Thus, it might depends on which version of compiling tools you use
>  for both RTEMS-4.10 and RTEMS-4.10.2.  Perhaps, the tools are not
>  interchangeable between 4.10.0 and 4.10.2, which I did not test yet.
>  Others might know these gcc tool patches better than me.
>  Hope this helps.
>  Cheers, Kate Feng
>  On 10/18/2012 07:24 PM, rwas wrote:
> > Kate Feng wrote:
> >> Yes,  RTEMS4.10.1 and RTEMS4.10.2 still have bugs.
> > Will these patches fix 4.10.2?
> > If 4.10.2 is this buggy I may go back to 4.9. :(
> > Thanks Kate.
> > Robert W.
> > _______________________________________________ rtems-users mailing
> > list rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
