build stuck: rtems-4.10.2, arm-elf, nds
Chris Johns
chrisj at rtems.org
Thu Apr 11 12:14:02 UTC 2013
Ralf Corsepius wrote:
> So far I deliberately had remained silent with my opinion on RSB, but
> you apparently "mean it",
Of course we do. It is a viable solution to building tools from source.
It is not unique and is friendly to RTEMS. It is nothing more than an
alternative our users can select.
> That said advising, people using these OSes to using packages which are
> build not using these OSes nominal buildsystems is BAD advise.
Are you saying you cannot build gcc from source on these hosts ?
