Debugging basic BSP tasking functionality
Sebastian Huber
Fri Apr 19 08:54:30 UTC 2013
On 04/19/2013 10:44 AM, Matthew J Fletcher wrote:
> >What do you mean with basic interrupt handlers?
> Not using the IRQ exception handler at 0x18, but like so.
> #define VICVectAddr0 REG32(0xFFFFF100) /* Vector Address 0 Register */
> #define VICIntEnable REG32(0xFFFFF010) /* Interrupt Enable Register */
> #define VICIntEnClear REG32(0xFFFFF014) /* Interrupt Enable Clear Register */
> #define VICIntSelect REG32(0xFFFFF00C) /* Interrupt Select Register */
> VICIntEnClear = VIC_BIT(VIC_TIMER0); // Ensure the interrupt is disabled
> VICVectAddr0 = (ULONG)tick_handler; // Address of the ISR
> VICIntSelect &= ~VIC_BIT(VIC_TIMER0); // Timer0 selected as IRQ
> VICIntEnable = VIC_BIT(VIC_TIMER0); // Timer0 interrupt enabled
> VICVectCntl0 = VIC_ENABLE | VIC_TIMER0;
This will not work.
> >If you want to keep your exception vectors in the flash, then simply use
> arm_exc_interrupt >(on 4.10) or _ARMV4_Exception_interrupt (on 4.11) as the
> entry point for the interrupt >exception.
> Do you mean passing arm_exc_interrupt as the handler into
> rtems_interrupt_handler_install() ? that still gives an unhandled IRQ
> exception, probably because there is no handler installed in 0x18.
No, the normal sequence is this:
1. Interrupt event
2. CPU calls _ARMV4_Exception_interrupt via exception table
3. This calls bsp_interrupt_dispatch (defined in the BSP)
4. This calls the handler installed via rtems_interrupt_handler_install()
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
