Fail to build hello.exe sample on NetBSD for BSP MIPS jmr3904.
Wed Aug 28 10:30:09 UTC 2013
Ivan Temp wrote:
>   I have been reading about RSB and I am willing to start with it but I
> am going need a lot of support.
1. Check out the RSB and then copy source-builder/sb/freebsd.py to
netbsd.py.
2. Edit options.py around 507 and get it to load netbsd.py.
3. Edit netbsd.py and set the specifics to match netbsd. To test cd into
the directory with netbsd.py and run 'python netbsd.py' and see the
values are ok.
4. Run the command sb-check.
