wrong input format was Re: Compiling Rtems by another compiler
Ehsan Salmanpour
salmanpour.ehsan at yahoo.com
Sat Aug 10 19:54:04 UTC 2013
I used examples of this compilation:
http://alanstechnotes.blogspot.com/2013/03/compiling-and-installing-rtems-for.html
but I didn't get any result. please check the link above and tell me if something is wrong.
________________________________
To: Ehsan Salmanpour <salmanpour.ehsan at yahoo.com>
Cc: Sebastian Huber <sebastian.huber at embedded-brains.de>; "rtems-users at rtems.org" <rtems-users at rtems.org>
Sent: Sunday, August 11, 2013 12:05 AM
Subject: wrong input format was Re: Compiling Rtems by another compiler
On 8/10/2013 1:59 PM, Ehsan Salmanpour wrote:
I don't need to compile with this compiler. As I said before I want to compile RTEMS for arm7 that can be simulated in SimpleScalar. when I use the original compiler of RTEMS (as mentioned in Docs) the SimpleScaler does NOT recognize the binary of the output.
This is what objcopy is for. What format does SimpleScalar
want the executable in?
If you can't answer that directly, how is one of their examples
or another program compiled and linked and prepared for
execution?
This is a common issue in embedded systems. The loader
on the target generally wants something special that is
not the direct output of ld.
--joel
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
>To: rtems-users at rtems.org
>Sent: Friday, August 9, 2013 10:27 AM
>Subject: Re: Compiling Rtems by another compiler
>On 2013-08-08 21:59, Ehsan Salmanpour wrote:
>> Hi Everyone!
>> I want to know is it possible to compile RTEMS with
another compile like:
>> *SimpleScalar/ARM Cross Compiler*
>> (https://sites.google.com/site/pkuwangh/solutions/arm_cross)
>> How?
>> My goal is compile Rtems for arm7 that can be
>Why do you need this compiler? The RTEMS GCC emits
standard EABI version 5 code.
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone : +49 89 189 47 41-16
>Fax : +49 89 189 47 41-09
>E-Mail : sebastian.huber at embedded-brains.de
>PGP : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im
Sinne des EHUG.
>_______________________________________________
>rtems-users mailing list
>http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D. Director of Research & Development joel.sherrill at OARcorp.com On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20130810/cfccf7ee/attachment-0001.html>
