Error while building gcc for toolset for RTEMS
manish jain
manish8886 at gmail.com
Thu Feb 7 11:22:03 UTC 2013
Hi,
I just started working on RTEMS development adn trying to build it. Before
building the RTEMS I am first building the required toolset. My host is
ubuntu so I am building everything from source code. I have been able to
build autoconf,automake,binutils,mps,gmp,mpfr successfully. But when I am
building the gcc for target as sparc I am getting the following error:
*configure: error: cannot compute suffix of object files: cannot compile
See `config.log' for more details.
make[1]: *** [configure-target-libgcc] Error 1
make[1]: Leaving directory `/home/manish/tools/b-gcc'
Can anybody tell me the source of this problem? I am using gcc-4.7.2 and
attaching the "config.log" with this mail.
Thanks
Manish
URL: <http://lists.rtems.org/pipermail/users/attachments/20130207/8e0ccd0d/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20130207/8e0ccd0d/attachment.obj>
