ARM (Thumb Mode) _CPU_Context_switch_arm
Mon Feb 25 16:52:45 UTC 2013
On 02/25/2013 05:47 PM, Matthew J Fletcher wrote:
> Hi,
> r2 is 0x13 before the msr, so I guess new_level must have been 0.
> On 25 Feb 2013 15:02, "Sebastian Huber" <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 02/25/2013 03:15 PM, Matthew J Fletcher wrote:
>         Sebastian,
>         The _Thread_Heir->Registers are ok into the _Context_Switch() call, sp
>         and lr
>         both sensible.
>         At the 'mrs r2, cpsr' line sp is 0x40001b2c (rubbish) and pc sensible.
>         In _restore, after the 'ldmia r1, ...' instruction the sp and lr are loaded
>         with the correct values from _Thread_Heir->Registers.
>         Its the 'msr cpsr, r2' messes up the sp and lr
>     Ok, if you load undefined values into the CPSR, then a lot of things may
>     happen.  What is the value of r2 before the msr?  It should be 0x13.
Ok, then maybe the mode in the BSP execution context is wrong.  During
_Context_Switch() no mode change must happen.  What is the CPSR before the msr?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
