rtems and Ubuntu 12.04
Ralf Corsepius ralf.corsepius at rtems.org
Sun Jan 13 18:42:28 UTC 2013
On 01/13/2013 06:47 PM, D Peter Siddons wrote:
> In building the RTEMS CVS head (4.10.99.0) on Ubuntu 12.04, 64-bit, I
> discovered a problem. Make fails in the build with the "C compiler
> cannot generate executables" error. I turns out that this is caused by
> the libcloog.so library being renamed in this distribution to
> libcloog-debian.so.0.0.0 and some similar links. I added a link from
> this to libcloog.so.0 and everything built successfully. Is this a known
> problem?
No, I have no idea what you are talking about.
Are you using my Ubuntu squeeze-packages?
Ralf
