Eclipse and Target Output
Cláudio Silva
claudiodcsilva at gmail.com
Wed Jan 30 09:29:33 UTC 2013
Hello,
You can integrate eclipse with TSIM and GRMON using the eclipse plugin
from Gaisler (it's free). It also explains some configuration steps
which may help answer your questions:
http://www.gaisler.com/eclipse/cdt/cdt.html
I personally don't use it, but it seems pretty nice.
Regards,
Cláudio
On Tue, Jan 29, 2013 at 2:22 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> I have been trying to learn more Eclipse so I can answer questions.
> I have managed to get a working hello world for sparc/sis. That much
> was easy. But when you run it in gdb, there is no output. So some
> questions:
> + How to see the output from a simulator built into gdb?
> + How do you all configure to Run not Debug?
> + Any advice on external simulators like qemu, tsim, skyeye, etc
> + Any other good advice?
> It would be great to move the Wiki beyond installing Eclipse into
> including more advice. I am sure you all are smart enough to have answers.
> Thanks.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.org
