Integrating RTEMS with ARM Cortex R4
Wed Jun 5 16:12:36 UTC 2013
On Wed, Jun 5, 2013 at 12:03 PM, Pritesh Gudge <priteshgudge at gmail.com> wrote:
>> > 1. Check if the CPU is supported: Cortex-R CPUs are supported as per the
>> > wiki page http://www.rtems.org/wiki/index.php/ARM-EABI
>> Yes, the Cortex-R is supported.  You should use the Thumb-2 instruction
> set.
>> > 2. Write a BSP for the requisite Board as it is not available for mine -
>> > This part I will figure out in due time.
>> > But kindly confirm statement 1.
>> > I have read your previous comment about the template LPC32XX BSP.
>> > I will be using the Texas Instrument Microcontroller TMS570LS3137 for
> the
>> > development. http://www.ti.com/product/tms570ls3137
>> > I just need a confirmation whether my understanding to this stage is
>> > correct. Only then will it make sense to commit to developing the
> requisite
>> > BSP.
>> I added a Cortex-A9 BSP recently.  If your chip uses the GIC interrupt
>> controller, then please use the code in
>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/shared/
> Hi,
> Thank you for your reply. As far as I checked my device allows
> the use of the ARM GIC interrupt controller. I will look into this
> and also that it is backward compatible with codes from ARM9 and ARM11
> architectures. I will look into this.
> Please keep us updated on all your additions to the ARM support.
> Also, if this is not possible how may I keep track of the same?
You may like to enroll in the rtems-devel mailing list so you can see
proposed patches that affect the ARM.
You could also enroll in rtems-vc, which posts all of the patches that
get committed to RTEMS, but that should be unnecessary.
> Thank you.
> Pritesh
> rtems-users mailing list
> rtems-users at rtems.org
