Integrating RTEMS with ARM Cortex R4
Sebastian Huber
Thu Jun 6 09:46:58 UTC 2013
On 06/05/2013 06:03 PM, Pritesh Gudge wrote:
> Thank you for your reply. As far as I checked my device allows
> the use of the ARM GIC interrupt controller. I will look into this
> and also that it is backward compatible with codes from ARM9 and ARM11
> architectures. I will look into this.
> Please keep us updated on all your additions to the ARM support.
> Also, if this is not possible how may I keep track of the same?
Please use this BSP as a template:
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/realview-pbx-a9
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
