Porting an embedded application to an RTEMS
Tue Mar 12 00:10:46 UTC 2013
manish jain wrote:
> Hi Everybody,
> I am doing an academic project in which I am going to port an existing
> embedded application to RTEMS.
Welcome.
> This embedded application is completely
> written in "C" and has various sensors and hardware units which
> interacts to processor periodically and here we want to introduce
> "RTEMS" task. I have already built "RTEMS" and able to run various
> examples in the repository but I am facing problem in where to start in
> "RTEMS" to port the application. Do I need to implement a separate "BSP"
> or device driver for the hardwares in application?
What hardware are using ?
Does a BSP exist for that hardware and did you run the examples on that
BSP ?
> I know I might be a little off topic here because this mailing list is
> completely dedicated to "RTEMS" development topic but I couldn't find a
> better forum than this as people here already using RTEMS.
This list is fine. RTEMS development question are normally directed to
the developers list.
