Program exited normally. SIGTERM
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Wed Sep 18 18:56:15 UTC 2013
On 9/18/2013 1:51 PM, Chris Johns wrote:
> Nicolás Alvarez wrote:
>> Dear all:
>> I`m having a strange problem in my code. Its runs for a few hours and it
>> finishes with this message:
>> *Program exited normally. SIGTERM*
>> or using gdb and grmon,
>> *program exited with code 0320*
>> It`s an undesired exit, but I can´t discover where and why it`s
>> happened. There are some method to track this bug? The app is a rtems
>> multitask running on Leon3 with grmon.
> I would run within gdb and set a break point in 'exit' and then do a
> backtrace using the 'bt' command. This should provide help find the area
> where the fail is happening.
Include rtems_shutdown_executive and _Internal_error_Occurred just
in case the shutdown is starting via another call.
My recollection is that a normal exit on the sparc's is via a
special system call or trap so you had to do this intentionally.
> Chris
> rtems-users mailing list
> rtems-users at rtems.org
