source builder failed when build for sparc
Sat Aug 2 06:33:32 UTC 2014
On 2/08/2014 1:54 pm, Peng Fan wrote:
> Hi,
> The command is:
> ../source-builder/sb-set-builder --log=l-sparc.txt
>   --prefix=/opt/rtems-4.11 --with-rtems 4.11/rtems-sparc
> Host:Opensuse 13.1 gcc-4.5.1 g++-4.5.1
> 117626 configure: error: in
> `/home/Freenix/per/source-builder/rtems-source-builder/rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-26-Jul-2014-1/build/sparc-rtems4.11/
>            libgcc':
> 117627 configure: error: cannot compute suffix of object files: cannot
> compile
> 117628 See `config.log' for more details.
> 117629 checking for suffix of object files... make[1]: Leaving directory
>          newlib-26-Jul-2014-1/build'
> 117630 make[1]: *** [configure-target-libgcc] Error 1
> 117631 make: *** [all] Error 2
> The logs are in the attchments.
I am not seeing this on sync.rtems.org (FreeBSD 10). I built a Windows
sparc tool set (with a pending disable sim patch) and that builds the
cross-compiler.
Is there something in the path that is causing an issue ?
