source builder failed when build for sparc
Peng Fan
van.freenix at gmail.com
Sat Aug 2 16:12:03 UTC 2014
2014-08-02 14:33 GMT+08:00 Chris Johns <chrisj at rtems.org>:
> On 2/08/2014 1:54 pm, Peng Fan wrote:
>> Hi,
>> The command is:
>> ../source-builder/sb-set-builder --log=l-sparc.txt
>> --prefix=/opt/rtems-4.11 --with-rtems 4.11/rtems-sparc
>> Host:Opensuse 13.1 gcc-4.5.1 g++-4.5.1
>> 117626 configure: error: in
>> `/home/Freenix/per/source-builder/rtems-source-builder/
>> rtems/build/sparc-rtems4.11-gcc-4.8.3-newlib-26-Jul-2014-
>> 1/build/sparc-rtems4.11/
>> libgcc':
>> 117627 configure: error: cannot compute suffix of object files: cannot
>> compile
>> 117628 See `config.log' for more details.
>> 117629 checking for suffix of object files... make[1]: Leaving directory
>> newlib-26-Jul-2014-1/build'
>> 117630 make[1]: *** [configure-target-libgcc] Error 1
>> 117631 make: *** [all] Error 2
>> The logs are in the attchments.
> I am not seeing this on sync.rtems.org (FreeBSD 10). I built a Windows
> sparc tool set (with a pending disable sim patch) and that builds the
> cross-compiler.
> Is there something in the path that is causing an issue ?
passed. There is some configure error in my system.
Regards,
Peng
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20140803/8e01b1d0/attachment-0002.html>
