rtems source builde git repository
Hoefle Marco
Marco.Hoefle at nanotronic.ch
Mon Aug 11 10:17:16 UTC 2014
Dear Chris,
thank you for your quick response. From the doku I understand that the syntax has changed.
I should use
%source set rtems_gr-4.10 git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
However I wanted to have a look how the other builds are working. Thus I checked out the latest commit from 2014-08-09
sb: Add INI format output to the reports.
The INI format report is a way to export a configuration.
There I wanted to build the normal sparc toolchain + rtems Kernel before I proceed with our gaisler patched rtems git tree:
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test/scripts$ cd ..
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test$ CUR_DIR=$PWD
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test$ TOOLCHAIN_DIR=$CUR_DIR/build/toolchain
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test$ RTEMS_SOURCE_BUILDER=$CUR_DIR/
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test$ mkdir -p $TOOLCHAIN_DIR
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test$ cd rtems-source-builder/rtems
hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems$ ../source-builder/sb-set-builder --log=$TOOLCHAIN_DIR/4.10-sparc.log --prefix=$TOOLCHAIN_DIR --no-clean 4.10/rtems-sparc.bset
RTEMS Source Builder - Set Builder, v0.4.0
Build Set: 4.10/rtems-sparc.bset
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
Build Set: Time 0:00:00.079997
Traceback (most recent call last):
File "../source-builder/sb-set-builder", line 26, in <module>
setbuilder.run()
File "../source-builder/sb/setbuilder.py", line 468, in run
b.build(deps)
File "../source-builder/sb/setbuilder.py", line 343, in build
self.build_package(configs[s], b)
File "../source-builder/sb/setbuilder.py", line 179, in build_package
_build.make()
File "../source-builder/sb/build.py", line 421, in make
self.prep(package)
File "../source-builder/sb/build.py", line 317, in prep
self.source_setup(package, args[1:])
File "../source-builder/sb/build.py", line 219, in source_setup
for source in self.source(setup_name):
File "../source-builder/sb/build.py", line 173, in source
src = download.parse_url(url, '_sourcedir', self.config, self.opts)
File "../source-builder/sb/download.py", line 222, in parse_url
_hash_check(source['file'], local, config.macros)
File "../source-builder/sb/download.py", line 56, in _hash_check
hash = sources.get_hash(file_.lower(), macros)
NameError: global name 'sources' is not defined
This was how I used rtems source builder before, is there something missing when trying v0.4.0?
Thanks,
Marco
-----Original Message-----
Sent: Sat 09/08/2014 05:11
To: Hoefle Marco; users at rtems.org
Subject: Re: rtems source builde git repository
On 9/08/2014 1:01 am, Hoefle Marco wrote:
> Hello,
> in rtems source build commit 2be445d2aafae21849c5d626b3787e2ab1ac846b
> this works:
> %define Source0 git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
> rtems source builder output:
> git: reset: git.nanotronic:rtems.git
> git: pull: git.nanotronic:rtems.git
> git: checkout: git.nanotronic:rtems.git => gr-4.10
> With the latest commit 8c19df26f679f53f22144c43b3141278e19da80e (and
> commits before probably as well)
> rtems source builder complains about malformed url.
> Is this as the URL does not start with git:// ?
You have not provided any output so it is difficult to say. I suspect it
is related to the changes I talk about below.
> Does anybody know why?
This commit ...
http://git.rtems.org/rtems-source-builder/diff/source-builder/sb/config.py?id=a083b52921a86a3bc49e2cc1d7d102612694557c
removed support for 'Source0' and 'Patch0'. Please refer to the
documentation:
http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/source-builder.html#_source
for details.
The %source0, %source1, etc and %patch0, %patch1, etc were difficult to
maintain and with this change there is no number and so no clashes. All
you do is add the source or patch.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140811/24a33b0b/attachment.html>
