rtems source builde git repository
Mon Aug 11 22:14:00 UTC 2014
On 11/08/2014 8:17 pm, Hoefle Marco wrote:
> Dear Chris,
> thank you for your quick response. From the doku I understand that the
> syntax has changed.
> I should use
> %source set rtems_gr-4.10
> git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
I would try:
%source set rtems git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
This will override the default in the RTEMS configuration script. The
script has:
  %source setup rtems -q -c -n %{name}-%{version}
so the label is 'rtems'.
> However I wanted to have a look how the other builds are working. Thus I
> checked out the latest commit from 2014-08-09
> sb: Add INI format output to the reports.
>      The INI format report is a way to export a configuration.
> There I wanted to build the normal sparc toolchain + rtems Kernel before
> I proceed with our gaisler patched rtems git tree:
Ouch. I have broken something while adding INI file support. I will take
a look and fix this. Sorry about this.
> hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test/scripts$
> cd ..
> hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test$
> CUR_DIR=$PWD
> TOOLCHAIN_DIR=$CUR_DIR/build/toolchain
> RTEMS_SOURCE_BUILDER=$CUR_DIR/
> mkdir -p $TOOLCHAIN_DIR
> cd rtems-source-builder/rtems
> hoefle at wheezy:~/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems$
> ../source-builder/sb-set-builder --log=$TOOLCHAIN_DIR/4.10-sparc.log
> --prefix=$TOOLCHAIN_DIR --no-clean 4.10/rtems-sparc.bset
> RTEMS Source Builder - Set Builder, v0.4.0
> Build Set: 4.10/rtems-sparc.bset
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-x86_64-linux-gnu-1
> Build Set: Time 0:00:00.079997
> Traceback (most recent call last):
>    File "../source-builder/sb-set-builder", line 26, in <module>
>      setbuilder.run()
>    File "../source-builder/sb/setbuilder.py", line 468, in run
>      b.build(deps)
>    File "../source-builder/sb/setbuilder.py", line 343, in build
>      self.build_package(configs[s], b)
>    File "../source-builder/sb/setbuilder.py", line 179, in build_package
>      _build.make()
>    File "../source-builder/sb/build.py", line 421, in make
>      self.prep(package)
>    File "../source-builder/sb/build.py", line 317, in prep
>      self.source_setup(package, args[1:])
>    File "../source-builder/sb/build.py", line 219, in source_setup
>      for source in self.source(setup_name):
>    File "../source-builder/sb/build.py", line 173, in source
>      src = download.parse_url(url, '_sourcedir', self.config, self.opts)
>    File "../source-builder/sb/download.py", line 222, in parse_url
>      _hash_check(source['file'], local, config.macros)
>    File "../source-builder/sb/download.py", line 56, in _hash_check
>      hash = sources.get_hash(file_.lower(), macros)
> NameError: global name 'sources' is not defined
> This was how I used rtems source builder before, is there something
> missing when trying v0.4.0?
> Thanks,
> Marco
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Sat 09/08/2014 05:11
> To: Hoefle Marco; users at rtems.org
> Subject: Re: rtems source builde git repository
> On 9/08/2014 1:01 am, Hoefle Marco wrote:
>  > Hello,
>  > in rtems source build commit 2be445d2aafae21849c5d626b3787e2ab1ac846b
>  > this works:
>  > %define Source0 git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
>  > rtems source builder output:
>  > git: reset: git.nanotronic:rtems.git
>  > git: pull: git.nanotronic:rtems.git
>  > git: checkout: git.nanotronic:rtems.git => gr-4.10
>  > With the latest commit 8c19df26f679f53f22144c43b3141278e19da80e (and
>  > commits before probably as well)
>  > rtems source builder complains about malformed url.
>  > Is this as the URL does not start with git:// ?
> You have not provided any output so it is difficult to say. I suspect it
> is related to the changes I talk about below.
>  > Does anybody know why?
> This commit ...
> http://git.rtems.org/rtems-source-builder/diff/source-builder/sb/config.py?id=a083b52921a86a3bc49e2cc1d7d102612694557c
> removed support for 'Source0' and 'Patch0'. Please refer to the
> documentation:
> http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/source-builder.html#_source
> for details.
> The %source0, %source1, etc and %patch0, %patch1, etc were difficult to
> maintain and with this change there is no number and so no clashes. All
> you do is add the source or patch.
> Chris
