Samples not built in the VM image
Tue Aug 12 19:33:40 UTC 2014
On Tue, Aug 12, 2014 at 3:31 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 8/12/2014 2:03 PM, David Shifflett wrote:
>> On 8/12/14 11:21 AM, Joel Sherrill wrote:
>>> On 8/12/2014 1:03 PM, David Shifflett wrote:
>>>> Hi,
>>>> I am new to RTEMS.
>>>> I downloaded the VM image,
>>>> and ran all the steps to update the OS, etc
>>>> also pulled the latest from GIT and ran the bootstrap,
>>>> all with no problems.
>>> That is good to hear. Last time I tried to cut a VM image it increased
>>> massively in size. :(
>>>> Finally I ran the suggested two build_bsp commands.
>>> Does this have "--enable-tests=samples" on the configure command?
>> Yes the helper script build_bsp has "--enable-tests=samples"
> Did the build succeed? Check b-<BSP>/b.log and b-<BSP>/c.log
> After the build passes, there should be about a dozen sample .ralf's
>>>> After this I could only find two applications, 1 for sparc and 1 for
>>>> i386, specifically
>>>> 'network-demos/netdemo/o-optimize/netdemo.ralf' (and '.exe').
>>> Those are leftover from a previous unrelated build.
>>>> Looking at the times on these files suggests they weren't recently
>>>> built, but included in the VM image.
>>>> How do I build the other sample applications?
>>> The examples in examples-v2 can be built using waf or by exporting
>>> RTEMS_MAKEFILE_PATH with the appropriate value. It would be
>>> something like ${prefix}/${target}/${bsp} where those get replaced
>>> with real values.
>> You've lost me here.
>> The VM has no examples-v2.
>> Is that something I should separately download?
> It is in a separate git repo on git.rtems.org so a git clone is needed
> if it isn't on there.
git clone git://git.rtems.org/examples-v2.git
>> Also, I've never used waf, is that included on the VM image,
>> or will I need to install it separately?
> I would just use the make technique
There is a README.waf file that explains how to do it.
>> What about building the code in
>> b-sis/sparc-rtems4.11/c/sis/testsuites/samples or
>> b-pc386/i386-rtems4.11/c/pc386/testsuites/samples?
>> I tried running 'make all' in those directories,
>> but got 'cannot find -lrtemsbsp'.
>> When was this library supposed to be created?
>> I couldn't find it anywhere.
>> Maybe my bootstrap did have some problems that I didn't see.
>> What is the best way to verify the environment and tools?
> Look at the log files I mentioned above. Something failed.
> Is your PATH correct?
>> Thanks again for your help,
>> dave
>>>> TIA,
>>>> dave
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> users mailing list
> users at rtems.org
