Samples not built in the VM image
David Shifflett shifflett at nps.edu
Tue Aug 12 20:57:35 UTC 2014
It appears that the builds did NOT succeed.
I apologize, I didn't carefully review the b.log files.
For each CPU there was a failure in building
rtems/c/src/libchip/network/dwmac-desc-enh.c related to __DEVOLATILE
It appears that this isn't defined, or the definition isn't found.
I see in other posts that this might be related to the version of newlib
installed in the VM.
i386-rtems4.11-gcc --version shows
i386-rtems4.11-gcc (GCC) 4.8.2 20131016 (RTEMS
gcc-4.8.2-4.el6/newlib-1.20.0-30el6)
That other thread talked a lot about patching newlib,
can I just update to newlib-2.1.0?
dave
On 8/12/14 12:31 PM, Joel Sherrill wrote:
> On 8/12/2014 2:03 PM, David Shifflett wrote:
>> On 8/12/14 11:21 AM, Joel Sherrill wrote:
>>> On 8/12/2014 1:03 PM, David Shifflett wrote:
>>>> Hi,
>>>> I am new to RTEMS.
>>>> I downloaded the VM image,
>>>> and ran all the steps to update the OS, etc
>>>> also pulled the latest from GIT and ran the bootstrap,
>>>> all with no problems.
>>> That is good to hear. Last time I tried to cut a VM image it increased
>>> massively in size. :(
>>>> Finally I ran the suggested two build_bsp commands.
>>> Does this have "--enable-tests=samples" on the configure command?
>> Yes the helper script build_bsp has "--enable-tests=samples"
> Did the build succeed? Check b-<BSP>/b.log and b-<BSP>/c.log
> After the build passes, there should be about a dozen sample .ralf's
>>>> After this I could only find two applications, 1 for sparc and 1 for
>>>> i386, specifically
>>>> 'network-demos/netdemo/o-optimize/netdemo.ralf' (and '.exe').
>>> Those are leftover from a previous unrelated build.
>>>> Looking at the times on these files suggests they weren't recently
>>>> built, but included in the VM image.
>>>> How do I build the other sample applications?
>>> The examples in examples-v2 can be built using waf or by exporting
>>> RTEMS_MAKEFILE_PATH with the appropriate value. It would be
>>> something like ${prefix}/${target}/${bsp} where those get replaced
>>> with real values.
>> You've lost me here.
>> The VM has no examples-v2.
>> Is that something I should separately download?
> It is in a separate git repo on git.rtems.org so a git clone is needed
> if it isn't on there.
>> Also, I've never used waf, is that included on the VM image,
>> or will I need to install it separately?
> I would just use the make technique
>> What about building the code in
>> b-sis/sparc-rtems4.11/c/sis/testsuites/samples or
>> b-pc386/i386-rtems4.11/c/pc386/testsuites/samples?
>> I tried running 'make all' in those directories,
>> but got 'cannot find -lrtemsbsp'.
>> When was this library supposed to be created?
>> I couldn't find it anywhere.
>> Maybe my bootstrap did have some problems that I didn't see.
>> What is the best way to verify the environment and tools?
> Look at the log files I mentioned above. Something failed.
> Is your PATH correct?
>> Thanks again for your help,
>> dave
>>>> TIA,
>>>> dave
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
