rtems source builde git repository
Wed Aug 27 09:46:04 UTC 2014
On 27/08/2014 7:17 pm, Hoefle Marco wrote:
> Hello Chris
> same failure:
> script: 74: cd
> "/home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/build/sparc-rtems4.10-kernel-4.10-1"
> script: 75: echo "=> sparc-rtems4.10-kernel-4.10-1:"
> script: 76: echo "==> %prep:"
> script: 77: source_dir_rtems="rtems-4.10"
> source setup: sparc-rtems4.10-kernel-4.10-1: source rtems -q -c -n
> sparc-rtems4.10-kernel-4.10-1-4.10
> making dir:
> /home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/sources/git
> _url:
> git://git.nanotronic:rtems.git?protocol=none?reset=hard?pull?branch=gr-4.10
> /home/NANOTRONIC/hoefle/projects/customers/unibern/cassis/clone/source_build_test/rtems-source-builder/rtems/sources/git/git.nanotronic:rtems.git
> git: clone: git://git.nanotronic:rtems.git ->
The code did not strip the protocol. Can you please add some prints
around the stop and test for me. I retested here and it is working.
I am on irc if you want to drop by to sort this out a little quicker.
