FW: Load module fail using RTL
Peng Fan
van.freenix at gmail.com
Thu Aug 14 01:40:36 UTC 2014
Hi,
First applying the patches at
http://lists.rtems.org/pipermail/devel/2014-August/007584.html
both is for rtl-host.
Then pass '--one-file' to rtems-ld, the it will add the object files in
libxx.a into the final rap image.
And u should pass '-m "xxxx" ', xxxx means bsp flags when u build your
sparc bsp. I am not familiar with sparc. Just like what u used, ' -m
"-msoft-float -mcpu=v8" ', if this is the bsp machine flags that u build
your bsp. u may refer to
http://lists.rtems.org/pipermail/devel/2014-August/007584.html to see
details.
The patch is in discussion, just a temproray way.
Regards,
Peng.
2014-08-13 4:49 GMT+08:00 Chris Johns <chrisj at rtems.org>:
> On 12/08/2014 7:10 pm, 박형식 wrote:
>> I try to follow way. I applied patch file to rtl-host and re-build. But
>> result is same.
>> It seems to do not include gcc libraries.
>> I include __floatsisf function in my base rtems. so that error do not
>> occurs, but other symbol could not find.(__gesf2)
> Did you use the same options to rtems-ld as gcc when linking ?
>> But, __addsf3 is not include in my rtems. but this symbol is linked by
>> libgcc.a
> Yes that will work but it means we may still have a bug and we should
> attempt to resolve this.
> Chris
> -----Original Message-----
>> From: Chris Johns [mailto:chrisj at rtems.org]
>> Sent: Tuesday, August 12, 2014 7:21 AM
>> To: hspark at satreci.com; users at rtems.org
>> Subject: Re: FW: Load module fail using RTL
>> On 11/08/2014 6:40 pm, 박형식 wrote:
>>> Hello,
>>> I develop some application using RTL library. But I have follow error.
>>> ·path : /ram:0/app_task module load fail : 22(global symbol not found:
>>> __addsf3)
>>> __floatsisf)
>>> ·My base rtems does not include library that include __addsf3,
>>> __floatsisf, but also I think my application does not include that.
>> These functions are found in libgcc.a.
>>> ·I use follow command for compile and linking for application.
>>> * Sparc-rtems-gcc -O2 -g -Wall -c -fmessage-length=0 -msoft-float
>>> -mcpu=v8
>>> * rtems-ld -e app_main --lib gcc --mcpu=v8 -b path/base_rtems -M
>>> -cc=C:/opt/rtems-4.10-mingw/bin/sparc-rtems-gcc
>> Hmm I wonder if this is related to Peng patch he posted on the devel list
>> the other day ...
>> It might be worth a try. I am yet to comment on this patch.
>> I use rtems 4.10 with leon3(sparc archecture).
>>> Why does not include __addsf3 and __floatsisf libraries in application?
>>> How can I include that functions in my application?
>> The rtems-ld should manage this. I suspect the options to gcc and the
>> rtems-ld are not lining up.
>> Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20140814/0d2a241c/attachment-0002.html>
