rtems source builde git repository
Chris Johns
chrisj at rtems.org
Wed Aug 27 08:46:32 UTC 2014
On 27/08/2014 5:28 pm, Hoefle Marco wrote:
> _url: git://git.nanotronic:rtems.git?reset=hard?pull?branch=gr-4.10
Can you please try the attached patch with the URL of:
git://git.nanotronic:rtems.git?protocol=none?reset=hard?pull?branch=gr-4.10
Thanks.
diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
index fbf9ce0..766e216 100644
--- a/source-builder/sb/download.py
+++ b/source-builder/sb/download.py
@@ -201,7 +201,7 @@ def parse_url(url, pathkey, config, opts):
source['url'] = url
colon = url.find(':')
if url[colon + 1:colon + 3] != '//':
- raise error.general('malforned URL: %s' % (url))
+ raise error.general('malforned URL (no protocol prefix): %s' % (url))
source['path'] = url[:colon + 3] + path.dirname(url[colon + 3:])
source['file'] = path.basename(url)
source['name'], source['ext'] = path.splitext(source['file'])
@@ -310,9 +310,27 @@ def _http_downloader(url, local, config, opts):
return not failed
def _git_downloader(url, local, config, opts):
+ repo = git.repo(local, opts, config.macros)
rlp = os.path.relpath(path.host(local))
us = url.split('?')
- repo = git.repo(local, opts, config.macros)
+ # Handle the various git protocols.
+ # remove 'git' from 'git://xxxx/xxxx?protocol=...'
+ url_base = us[0][len('git'):]
+ for a in us[1:]:
+ _as = a.split('=')
+ if _as[0] == 'protocol':
+ if len(_as) != 2:
+ raise error.general('invalid git protocol option: %s' % (_as))
+ if _as[1] == 'none':
+ # remove the rest of the protocol header leaving nothing.
+ us[0] = url_base[len('://'):]
+ else:
+ if _as[1] not in ['ssh', 'git', 'http', 'https', 'ftp', 'ftps', 'rsync']:
+ raise error.general('unknown git protocol: %s' % (_as[1]))
+ us[0] = _as[1] + url_base
if not repo.valid():
log.notice('git: clone: %s -> %s' % (us[0], rlp))
if not opts.dry_run():
@@ -350,6 +368,10 @@ def _git_downloader(url, local, config, opts):
log.notice('git: reset: %s' % (us[0]))
repo.reset(arg)
+ elif _as[0] == 'protocol':
+ pass
+ else:
+ raise error.general('invalid git option: %s' % (_as))
return True
def _cvs_downloader(url, local, config, opts):
